chipmixer
ZacheryHiree
chipmixer
Сообщение ZacheryHiree » 12 сен 2022, 17:28
blender io
Top 11 Bitcoin Mixers and Tumblers to use in 2022 and Beyond
Best Bitcoin blender 2022, Top 5 Bitcoin mixer, Top 10 Bitcoin mixer, Bitcoin mixer
BTC Blender | Bitcoin Wallet Mixer
BTC Blender is TOP rated Bitcoin Mixer Wallet No Logs, No KYC, No AML, Anonymous Bitcoin Tumbling Service
10 Best Bitcoin Mixers and Tumblers in 2022
With privacy becoming more valuable, bitcoin mixing could become more important Here are the ten of the best bitcoin mixers in 2022
Bitcoin/BTC Mixer | Reviews – Best Bitcoin Tumbler/Blender
Bitcoin Mixer | Bitcoin Mix Service | Bitcoin Tumbler
itcoin Mix greatly contributes to protecting user identification by applying the latest algorithm, and also acts as Bitcoin Blender and Bitcoin Tumbler
Bitcoin Mixer (Tumbler). Bitcoin Blender.
Looking for trusted bitcoin mixing service We do not collect any logs Bitcoin mixer tumbler is fully automated and will keep your anonymity
10 BEST Bitcoin Mixers & Tumblers (2022 List)
Bitcoin Mixer is a service that enables you to send your bitcoins through a series of anonymous transactions
BITCOIN MIXER | Bitcoin Mixer (Blender) is something that helps you to shuffle your bitcoins using our algorithms and to secure your identity.
Bitcoin Mixer is a service that enables you to send your bitcoins through a series of anonymous transactions. This makes it much more difficult to trace the source of the funds which makes Bitcoin mixers a popular choice for those looking to keep their identity hidden.
Many Bitcoin mixers are available, but not all of them are created equal. Some mixers are known not to be honest, while others charge high fees, so selecting one is a difficult task. The following is a curated list of the Top Bitcoin Mixers & Tumblers with their features, pros, cons, key specs, pricing, and website links.
1. Blender.io
Lastly, there is . This is another easy to use Bitcoin mixer that you can try out. Also, it doesn't require you to have any pre-mixing knowledge.
The best part of the website is that it allows the users to determine how much they want to pay as a service fee. Also, it has a welcome minimum deposit fee. So you can experiment with the website.
It charges a service fee between 0.05% and 2.5%. And as a user, you can choose the amount to be paid for each transaction.
Moreover, it requires a minimum deposit of 0.01 BTC. Along with that, it is extremely fast. As it requires only one network confirmation to process your order. Additionally, you can add a delay of up to 24 hours.
Plus, it supports multiple BTC addresses. Also, it has a no data retention policy. As a result, all data gets deleted after 24 hours of executing an order.
Closing Words:
So that was all about what is a Bitcoin mixer and the top bitcoin mixers and tumblers available out there. Now go ahead and check these services out and see if they are working for you. Also, for any other questions, do feel free to comment below.
2. [url=https://cryptomixer-btc.com]CryptoMixer
Next, there is the CryptoMixer. The platform offers you a letter of guarantee for every transaction, and it is extremely secure.
CryptoMixer uses advanced encryption methods to ensure the integrity of all data stored. Plus, it minimizes the risk of blockchain analysis. Along with that, it provides you with a unique code to prevent mixing their coins with the ones they've sent to us before.
Along with that, it offers you impressive mixing capabilities. It doesn't matter if you want to mix 0.001 BTC or several hundreds of coins, it offers you a convenient solution.
Also, it has over 2000 BTC in its cryptocurrency reserves. So mixing large amounts of bitcoins won't be an issue.
Along with that, it only charges 1% and more for each transaction. Also, it helps you avoid overspending as it offers you affordable fees, which are about 0.5% + 0.0005 BTC and can be customized.
3. Foxmixer.biz
FoxMixer makes it harder for anyone to trace back bitcoin transactions using an algorithm that automatically mixes and replaces coins. It mixes users’ bitcoins into a pool of coins. This platform also monitors the currency volume transactions to be able to shift payouts if necessary.
Blockchain analysis services can track the origin of a transaction using nodes in multiple countries. This mixer offers the option to randomize the origins of the coins you send to the platform, which makes it harder to trace them back to your IP.
FoxMixer has a flat service fee of 0.001 BTC for every output bitcoin address you use, and a 1% fee they deduct from the transaction.
FoxMixer benefits
“No Data Retention” policy. All logs are deleted within 24 hours after the transaction has been completed.
Accessible via Tor
Offers a Letter of Guarantee
Offers random transactions according to the current trading volume, to make your transaction blend in.
4. ULTRAMIXER
Next, there is the ULTRAMIXER. This one is one of the high-quality bitcoin mixing services available out there. The platform makes it extremely easy to mix your cryptocurrency.
FoxMixer works as a state of the art service for restoring and keeping security and privacy in the bitcoin ecosystem. It accepts your Bitcoin and mixes them in a huge and constantly changing pool of Bitcoin, and returns a new and fully independent set of Bitcoins.
As a result, it comes tough for backtracking of transactions. So no one will get to know where you have spent your bitcoins.
Along with that, it also offers you a detailed page that informs you about the current progress of every mix. So you can get quick information about the procedure.
Also, once a mix is created, the individual status page is the central and reliable source of information throughout the whole lifecycle of the mix. So you can bookmark the page to get every information about your mix.
Plus, it offers random transactions according to the current trading volume. This really helps in making your transactions blend in.
5. SmartMixer
SmartMixer is another popular service that you can try out. The service is extremely easy. All you need to do is enter the address and send coins, and the platform will mix your coins. Then the receiver will get untraceable coins.
The platform gives you 100% anonymity by deleting all the details of transactions immediately after mixing.
Along with that, the link to check the status of the mixing process will get deleted 24 after or you can delete it manually. Also, it doesn't really require any personal information from you. Or you need to create an account.
In addition to that, it uses 3 different pools with cryptocurrencies of different combinations of sources. As a result, your bitcoin becomes completely anonymous.
Moreover, SmartMixer also has affordable services fees as it only charges you 1%. The discount will be automatically calculated depending on the total amount on each currency you have mixed.
Also, it is extremely fast. As it only requires two confirmations to complete a transaction.
6. Anonymix
Up next, there is the Anonymix. This Bitcoin mixer offers you tons of features, and it is extremely easy to use. The best part of Anonymix is that it comes with speed and security.
You can simply choose a quick mix to receive your coins after one confirmation. Also, you can implement extra security by using a timed or random delay to make your coins difficult to track.
It is also a high capacity mixer. As the platform holds crypto assets in both hot and cold storage. And the mix can handle up to 180 bitcoins.
Furthermore, you can increase the security of your mix by making deposits from multiple wallets. Or send your mixed funds to up to five receiving addresses. Also, it issues a certificate of origin with every mix.
What's more? The platform also keeps zero logs. Plus, it offers you the option to delete your mix immediately. Or it gets auto-deleted after one week.
7. Mixertumbler
You can also try using the Mixer Tumbler. It is one of the best Bitcoin mixers that allows you to send BTC anonymously. It uses several Bitcoin pools for low value and high-value transactions. As a result, you will receive untraceable coins.
Also, its mixer cannot be listed by blockchain analysis or other forms of research. So your coins are protected.
As well as it ensures that your identity is private, as it has a no-logs policy. Also, the platform deletes your transaction history 24 hours after your order has been executed. Plus, there is no need to sign up.
The platform also charges pretty low fees. The fees range from 1-5%. Also, you can enjoy other discounts.
What's more? The website is also tor friendly which will encrypt all your transactions and locations. So none of your information gets leaked.
8. ChipMixer
First of all, there is the ChipMixer. This one is one of the popular Bitcoin mixers available out there, which is pretty easy to use and secure. The user interface is so simple that you don't need any technical expertise to use it.
The best part of this one is that it offers you full control over mixing. Plus, the outputs are fungible, meaning that each chip is exactly the same. Also, you can withdraw your private keys instantly, and it offers you faster outputs.
Along with that, it also allows you to merge small chops into big ones. Also, its first mixer allows you to merge inputs privately.
There is also no need to sign up for an account that makes your activity completely anonymous. Also, you get a receipt of receiving funds from ChipMixer, which will act as a signed source of funds.
What's more? The service uses predefined wallets to deliver your Bitcoin. This makes tracing impossible. Also, it functions as a donation only service.
9. Mycryptomixer
Cryptomixer is one of the few bitcoin mixers with really large transaction volumes.
The minimum amount of a mixing operation is 0.001 BTC, any amount below this set limit is considered a donation and is not sent back to the client, there is no maximum credit limit.
The minimum fee is 0.5% with an additional fee of 0.0005 BTC for each deposit.
When making a transaction, you will receive a letter of guarantee, as in all all the previously mentioned mixers.
10. Smartmixers
This is a simple service that helps to hide the traces of your cryptocurrency transactions by mixing them with other coin transfer transactions.
The process only takes a couple of minutes. It is enough to choose one of the three supported coins (Bitcoin, Litecoin, Bitcoin Cash), enter the recipient's address, set a time delay for any time up to 72 hours, send the required amount to the specified address and wait for them to be delivered to their destination.
This site differs from others in that it offers three cleaning pools. It is possible to mix client's coins: with credited bitcoins of other users, private reserves of the platform and investors' coins.
The mixer does not require registration.
The cleaning fee is not large and is taken from the mining fee, which is very convenient.
SmartMixer's referral program is one of the most profitable, during the first transaction you receive a smart code that is required to receive a commission discount, this discount can reach 70%.
Each transaction is backed by a letter of guarantee. All data about it is deleted after 24 hours, maintaining the complete confidentiality of the client.
11. Coinmixerbtc
BTC Blender makes the coin cleaning process extremely easy and user friendly.
BTC Blender requires only one confirmation, after which it sends new cleared coins to the specified wallet. Clients also have the ability to set delays for the processing of their transactions.
This is an offshore service, and its sites are also located offshore. This provides users with additional peace of mind and confidence that their data is strictly confidential. In addition, once a transaction is confirmed, a unique “delete logs” link is made available to users, allowing users to delete their transaction traces manually.
BTC Blender charges a modest commission of 0.5%. This makes BTC Blender the best option for users clearing large amounts.
